Creating ovals
The Oval tool has multiple creation modes, and the Push/Pull mode is available in 3D views for instantly extruding the oval after creation.
Mode
Description
Box
Defines the dimensions of the box containing the oval
Height and Width
Defines the height and width distances to create the oval
Center
Defines the center, then the major and minor radii to create the oval
Push/Pull
(3D views only)
Instantly extrudes the oval after creation; see Push/Pull mode of planar tools
Push/Pull Combine
(available with Push/Pull mode)
When the shape to be extruded is drawn on the face of a solid object, combines the two objects into a single solid addition or solid subtraction; when this submode is disabled, the new extrude remains a separate object, and the existing solid object remains unchanged
Oval by box
Mode
Tool
Tool set
Shortcut
Box
Oval
Basic
Alt+6 (Windows)
Option+6 (Mac)
To create an oval by box:
Click the tool and mode.
Click to set the first point of the box containing the oval and then click again to set the box size.
To create a true circle, press the Shift key while creating the oval.
Oval by height and width
Mode
Tool
Tool set
Shortcut
Height and Width
Oval
Basic
Alt+6 (Windows)
Option+6 (Mac)
To create an oval by height and width:
Click to set the first point of the oval height, and then move the cursor to define the height.
Move the cursor, and then click to define the oval width.
Oval by center
Mode
Tool
Tool set
Shortcut
Center
Oval
Basic
Alt+6 (Windows)
Option+6 (Mac)
To create an oval by center:
Click to set the center point of the oval, and then move the cursor and click to define one of the radii.
Move the cursor and then click to define the other radius.
